Gas pipe-pressure-renderingcorrosion-confused !
Brian
by Brian » Mon Apr 06, 2009 2:26 pm
I am your typical Joe Public, I can read about gas boilers and systems etc and then ask the Gassaferegister listed person to come and look and give me a quote for the work required. It is ME that pays the bill.
Installer A looks at the gas feed pipe from meter to boiler-10m distance-with take off for gas hob, and says that the present 15mm copper pipe will not do because it won't carry enough gas pressure and will need a 22mm pipe.
Installer B looks at same pipe and says that the concrete rendering over the Victorian brickwork that uses the 15mm copper pipe as an edge/finish line, about 8 inches above ground level, will not do as rendering corrodes the copper and will not get signed off. Rendering has been there for 20 yrs.
A said nothing about this rendering and B said nothing about gas pressure.
This Joe Public is now confused by the comments/non-comments of two registered, qualified installers.
Are they both correct , but missed a bit or what !!!???
Comments please.
Brian
Think this is the best page to ask .
by htg engineer » Mon Apr 06, 2009 5:47 pm
They are both correct.
Maybe installer A didn't mention the rendering because - as he says the 15mm pipe is no good, and would have to be upgraded to 22mm - so the 15mm pipe will not be used and if it corrodes it wont matter.
Maybe B has said he cannot leave the pipe in because the rendering will corrode the pipe, if you said ok replace it - he may have said ok i'll replace it in 22mm ?
Really you will have to ask them - but they are both right, unprotected pipework will corrode and 15mm pipework is no good to feed a boiler and a gas cooker - 22mm would be the minimum size - 28mm if a longer run.
htg
Steve the gas
by Steve the gas » Tue Apr 07, 2009 5:53 am
Ditto
It is currently Thu Jul 04, 2024 7:54 pm
