waste pipe outside house
kgwalker
by kgwalker » Wed Apr 08, 2009 6:22 pm
i have a problem with the waste pipe outside my house as its dripping in to my neighbours garden. The pipe is near the room connected to the loft. What should i do
by htg engineer » Fri Apr 10, 2009 11:11 am
Fix it!
What is the waste pipe for ?
If it's from a joint, is it solvent weld or push-fit ?
Solvent weld - try applying solvent weld to the joint.
Pushfit - pull apart, check rubber o ring and replace if necessary.
htg
rosebery
by rosebery » Fri Apr 10, 2009 2:19 pm
Or is it the overflow from one of the tanks in the loft (assuming you have tanks in your loft)?
If it is - fix it as HE says.
In this case either the ballvalve is incorrectly adjusted and is overfilling OR it needs a new washer / HP cone.
It is currently Tue Dec 03, 2024 8:43 pm
