Water from power shower not hot enough!
mandyg
by mandyg » Sun Apr 12, 2009 7:35 pm
Hi. I have a Redring Superflow 3000 power shower which is nearly 10 years old and is now not giving me hot enough water. I am having to set the dial to a higher and higher setting each time I use it. Do you think its days are numbered and the pump is dying or maybe there is a filter on it that needs cleaning or something. Your help would be much appreciated!
rosebery
by rosebery » Mon Apr 13, 2009 10:20 pm
The shower you mention is an electric shower (fed by mains cold) rather than a power shower (pumped hot and cold fed by tank in roof).
It's more than likely that it's all scaled up. You could try to descale it using a plumbers descaler based on sulphamic acid, or orthophosphoric acid and you'll get the job done quite quickly. It may take more than one filling though, as there's a lot of heating element and not much water volume inside the heater.
Alternatively you could try replacing the heater. Google "showerdoc.co.uk/shower-spares/redring/index.html" or "showerspares.com/products/spare_parts/redring_superflow_3000" but theres a fair chance that you won't see much change out of the cost of a replacement shower. That has to be balanced against the fact that a new shower will NOT exactly fit the pipework and fixing arrangments of the old one requiring some adjustment.
HTH
mandyg
by mandyg » Wed Apr 15, 2009 9:32 am
Thank very much for your reply but the shower is a hot and cold feed from the water tanks. The shower unit itself has a built in thermostatic pump. But I do think you are correct in saying the repair cost outweighing the cost of replacing, so I am going to replace it. Thanks anyway!
rosebery
by rosebery » Wed Apr 15, 2009 9:27 pm
"Thank very much for your reply but the shower is a hot and cold feed from the water tanks."
Dang it!! That'll teach me to rely soley on the old grey cells for data retrieval!!
It is currently Tue Dec 03, 2024 8:29 pm
