Sump pumps and mascerators
hobbis
by hobbis » Sat Apr 18, 2009 11:01 am
We are building a garage/workshop at the back of our house and would like to install a toilet and wash basin. The sewage and main drain is at the top of a slope so we think we will need a pump of some sort I have looked at some pumps which are buried and we are not sure whether the pumps are also mascerators or if that has to be added sepaerately. We will at some stage also want to put the washing machine in there. Can any one help. The sewage pipe is victorianand the fall from the top of the slope isn't brilliant. The sewage drain is aproximately 20ft from the front of the workshop. HELP please would be gratefully appreciated. Thank you in anticipation.
plumbbob
by plumbbob » Sat Apr 18, 2009 9:24 pm
A strange topic for loft conversions?
Anyway,
You can't use an ordinary pump for anything other than ordinary water and even then they may struggle with "dirty" water.
If you intend to install a washing machine you could use one of these.
http://www.awin1.com/awclick.php?mid=12 ... -Pump-250W
Toilets need a mascerator (which chops stuff up) such as
http://www.awin1.com/awclick.php?mid=12 ... Suite-400W
Only use a pump if the fall or distance make it impossible to connect by conventional means.
hobbis
by hobbis » Mon Apr 20, 2009 3:37 pm
Thanks Plumbbob for your reply - I think I pressed the wrong section when posting my Q. Will try harder next time. Thanks again.
It is currently Wed Oct 02, 2024 9:04 am
