Kitchen worktop joints
harry barker
by harry barker » Sat Apr 18, 2009 7:39 pm
Is there any need to use beech biscuit joints when joining two laminate work tops together if so what size 10 or 20
by stoneyboy » Sun Apr 19, 2009 3:43 pm
harry barker,
Using biscuits will help line up the worktop surfaces but you will still have to make fine adjustments - use the larger ones.
rosebery
by rosebery » Sun Apr 19, 2009 5:19 pm
I would say yes. Use 3 worktop bolts in addition to 4 size 20 biscuit joints.
plumbbob
by plumbbob » Mon Apr 20, 2009 12:12 am
I am sure biscuits may seem like a better decision, but in all the years I have been involved in taking out old kitchens and all the fitters I have known and employed, (and including myself), putting in new ones, which must run into hundreds of installations, I can count on one hand with fingers to spare the number where biscuits have been used.
As Stoneyboy says, they don't help any with lining up as you have to make the fine adjustments, and if fixed properly, when the joint is set, it is SET.
It is currently Fri Jan 10, 2025 3:19 am
