Rough Render
ritathale
Rough Render
by ritathale » Wed Apr 22, 2009 2:33 pm
Please offer some guidance to a complete amateur .
I have a large , 1930's , detached house . Over the years , as each
extension / renovation has been completed , renderers have done their best
to match up the new / repaired render to the original , using a trowel pattern
which now looks like a dog's breakfast .
The render is very solid . Is there a tool , perhaps some sort of grinder ,
which could be used to remove much of this pattern prior to painting ( the
deepest ridge is no more than 1 cm deep ) ?
If not , is there a sealing agent that would bind all of the layers of old paint
to the render prior to painting including the small ( hand - sized ) areas
that have lifted from the rendered surface ?
Many thanks !!
by stoneyboy » Fri Apr 24, 2009 12:22 am
ritathale,
An almost impossible task to grind down the surface.
Try using stabilising solution on the bare rendered areas prior to over-painting.
youasked
bit of a do.
by youasked » Fri May 08, 2009 1:06 pm
Not impossible, but hard messy work.
1) Angle grinder. Messy and noisey.
2) Hire a compressor, buy a couple of air hammers (small ones about £25), get on with it.... OR
3) just go over the whole lot with Decopierre or some other high build product.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jul 05, 2010 7:55 pm
Find trusted, insured and vetted tradesman local to your area. Visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Sat Nov 23, 2024 1:27 am
