Bathroom flooring
spiker
Bathroom flooring
by spiker » Thu May 24, 2007 9:22 pm
Just need some advice on laying a floor in the bathroom
previously had carpet which I took up to reveal basic floorboards
planning on using vinyl / vinyl tiles over the top as a cheap and easy diy solution as I am hopeless
Do I need to seal the wood first ?
Should I use anything underneath the vinyl ?
The floor is fairly even although there are a couple of holes in the floorboard ( some a couple of cms )
thedoctor
by thedoctor » Thu May 24, 2007 10:08 pm
You need to fix 6mm plywood to the floorboards first and then seal it with one coat of PVA adhesive mixed 50/50 with water, then another coat of undiluted PVA (see our project on PVA) then lay the tiles. If you lay them directly onto boards, especially boards with holes, the joints will very soon show through the tiles which will eventually crack in these places. Timber floors move a great deal, especially in bathrooms and every single little crack, split or holes will show through the tiles sooner or later.
spiker
by spiker » Thu May 24, 2007 10:10 pm
Thanks for your help
spiker
by spiker » Wed May 30, 2007 1:09 pm
Ok plywood down and screwed to the boards - all nice and flat
Next I need to do the pva coating but I cannot find the project you mentioned on the forum - where can I find it
It is currently Sun Dec 22, 2024 10:58 am
