Cupboard door
gerryyy
Cupboard door
by gerryyy » Mon May 25, 2009 12:54 am
making a storage space in the corner of the room. using a door measuring 1961mm by 762mm. What space do i need to leave for door? would 2 or 3mm right around be enough?
rosebery
by rosebery » Mon May 25, 2009 10:00 pm
Probably be OK but I'd certainly leave a lot more than that at the bottom considering whatever floor covering you are using.
Its almost inevitable whatever you do that unless you spend a lot of time getting the door casing exactly right that you'll end up trimming the door a little. That shouldn't concern you as its easier to make the dor fit the case than the other way round.
It is currently Tue Nov 26, 2024 8:35 am
