Single skin brickwork garage - how to stop damp/salts?
m33ufo
by m33ufo » Mon May 25, 2009 10:17 am
I'm hoping someone can suggest a solution to my problem. It's a single skin brickwork garage and I'm getting fed up of all the dust accumulating as a result of salts on the surface of the brickwork - the walls get damp and leave salts on the surface as they dry (pain in the butt!).
I was thinking of applying a coating to the inner wall surface. What would work? Would a PVA solution help?
Cheers guys.
by stoneyboy » Mon May 25, 2009 11:10 pm
m33ufo,
Apply a few coats of silicone liquid to the outer of the wall. Definitely not PVA to the inner surface.
m33ufo
by m33ufo » Tue May 26, 2009 10:34 am
Siicone liquid, would that be something like Thompson Water Seal?
Can I ask why an internal PVA coating would be a bad idea? What I'd like to do is create an internal barrier to stop efflorescence accumulation on the surface of the brickwork.
Similarly, what about Thompson Paving and Patio Seal - would that be suitable for coating brickwork internally? I'm also looking at acrylic coatings etc.
by stoneyboy » Fri May 29, 2009 9:36 pm
m33ufo,
Yes thompsons water seal is fine.
PVA is a waterbased solution and does not chemically set - it only dries.
Once you stop the water penetrating from outside the salts will stop appearing. Leave the inside uncoated and moisture in the wall can the disperse.
It is currently Sat Feb 08, 2025 8:42 am
