Power to 240v or 12V uplights outside, from a socket inside?
stevey4
by stevey4 » Wed Jun 03, 2009 10:14 pm
Right here goes,
I have one socket indoors available, this already has a switched fused spur powering a light on the outside of the house.
From this socket or light i need to run about 6 meters under ground to the back of the garden and power a selection of sunken uplighters.
If I took the light out of the equation, i believe i could replace the switched fused spur with an RCD protected fuse spur and run armoured from that.
Does anyone have a better idea and maybe including the current light on the wall.
Cheers,
Steve.
kbrownie
by kbrownie » Thu Jun 04, 2009 10:11 am
stevey4,
First thing is to consider regulations and legal requirements:
It is notifiable Part P work if you are DIYing so look on project pages for part p or needs to be installed by an electricain that is registered on a domestic installers scheme.
The requirements for cable underground is at least 600mm in an area that may be disturbed ie garden tools etc or at least 400mm if concrete path/driveway.
The cable should be layed in sand so no stone/bricks can damage and be covered with coping stone and yellow/black indication tape over that.
This circuit should be RCD protected either at spur as far as light just link it up to circuit.
KB
It is currently Sat Jan 18, 2025 6:22 pm
