Roof truss bracing/strapping
col111
by col111 » Thu Jun 11, 2009 2:22 pm
A surveyor has advised that additional bracing/strapping to roof trusses should be provided to a 1970's flat I am buying, to comply with current building practice. I have seen different types of roofs & trusses, where can I get details of current building practice to be able to do it myself? Is it an expensive job if I get a roofer to do it? What is strapping?
by stoneyboy » Fri Jun 12, 2009 8:56 pm
col111,
You must get a drawing from your surveyor installation should be straighforward once you see what is needed.
col111
by col111 » Sat Jun 13, 2009 10:43 am
Thanks stoneyboy, I will try to contact the surveyor (it was the mortgage lenders surveyor who did the survey, I have not had direct contact with him as yet).
It is currently Mon Nov 25, 2024 7:19 pm
