gas safety checks
emmaowentaylor@yahoo.co.u
gas safety checks
by emmaowentaylor@yahoo.co.u » Thu Jun 11, 2009 3:07 pm
after work has been carried out on a combi boiler,, by a qualified gas engineer, when looking at paper work what safety checks should have been carried out?
by htg engineer » Fri Jun 12, 2009 2:37 pm
It depends on what work was carried out, why ? what's the problem ?
If he worked on the water section of the boiler, then basic visual checks would suffice. If he worked on the gas section then he should carry out tightness tests, set/check gas pressures where necessary - possibly carry out flue gas analysis checks (depends on work undertaken and boiler type).
htg
It is currently Fri Feb 07, 2025 12:22 pm
