Outside light switch and lights
ronecc
by ronecc » Sun Jun 21, 2009 12:52 pm
I am fitting a waterproof light switch to two exterior lights. My switch has three terminals numbered, L, 1 and at the bottom 2. All my wires are brown, blue and yellow/green. Which go where?
kbrownie
by kbrownie » Sun Jun 21, 2009 8:10 pm
Have you contacted building controls as this work comes under part p of building regs, or is this replacing an old switch?
KB
bd3cc
by bd3cc » Sun Jun 21, 2009 10:40 pm
Brown to L, blue to either 1 or 2: if incorrect switch will be upside down.You may find marked on the switch" for 1 way use 1 or 2, if so follow that instruction.
Blue should be sleeved/flagged as a brown.
green/yellow in a dummy terminal, which may be in the mounting box.
ronecc
by ronecc » Mon Jun 22, 2009 12:42 am
\\\\thanks for the replies. Got it sorted now. Brain must have been out of gear and could not remember what went where.
It is currently Mon Dec 23, 2024 8:57 am
