Solar panel system installation help!
Fishcat68
by Fishcat68 » Wed Jul 01, 2009 9:23 am
Hi, we have recently renovated a house and took the opportunity to get solar panels installed along with a new boiler system and underfloor heating on the ground floor. Whilst the heating system seems to work OK (seems very expensive to run but beside the point), we do not fully understand the set up of the panels, boiler etc. To cut a long story short, there is water constantly dripping out of a pipe from either the boiler or the panels. The builder says this is perfectly normal, but it just doesn't seem right. There is an expansion vessel connected to the system that is completely empty - should this not fill up before the water drips out?
The boiler is from Keston and the panels and pump for the solar are from Worcester Bosch so at the moment we can only trust that what the builder and plumber are saying is true. There is also a Manco unvented cylinder connected to everything.
The solar system has been losing pressure. They say they have fixed it and all is now OK but it is currently at 0.5 bar and the manual says it should be between 1.5 and 2.2 but we are not experts so are loath to say they are both wrong and we are right. Can somebody help? Should we get someone else in to check it all out? Many thanks!
by htg engineer » Thu Jul 02, 2009 3:52 pm
Firstly what pipe is dripping ? a copper pipe or plastic pipe ?
Plastic - maybe condensate discharge piepwork from boiler, should terminate into a drain and you shouldn't be able to see it dripping really as it should below the top of the gully, hopperhead etc.
If it's a copper pipe - it could be pressure relief discharge -shouldn't be dripping at all, the PRV is either passing or the expasnion vessel isn't doing it's job.
htg
Perry525
by Perry525 » Mon Jul 06, 2009 6:41 pm
I am intrigued by your comment that your central heating is expensive to run, as we have just been through the hottest patch this year.
What size home do you have, square feet/cubic feet?
What type of system?
How is it controlled?
How often do you have it on and for how long?
What sort of insulation and windows do you have?
Have you gone round blocking all the holes that loose heat?
Are your heating bills above average?
What tariffs are you on?
All the above have to be factored into heating cost.
It is currently Fri Feb 07, 2025 7:22 pm
