Laying block on flat (concrete foundation depth)
Paul-E
by Paul-E » Mon Jul 06, 2009 4:29 pm
Hello,
I have looked at projects but no joy on info I require.
My garden slopes away from house in two directions so to lay patio I need to raise level. I have stepped foundations.
At the lowest point I would need 5 blocks (layed flat) at a length of around 4m to bring side up to level I require then step them accordingly across the front of patio then fill with hardcore.
I have 300mm width foundations and was going to peg at 150mm ready for concrete.
Is the 150mm concrete too much for the 5 high flat block or should I stick with that? I have read I could get away with 100mm ...would this be ok?
As I say, could not find any info in projects, If I have missed something please advise and I will look again.
Paul.
TheDoctor4
by TheDoctor4 » Mon Jul 06, 2009 5:15 pm
Have you had a look at the garden retaining wall project: https://www.diydoctor.org.uk/projects/retainingwall.htm . Not too sure if you have seen this one but it may help you out.
Regards
It is currently Mon Nov 25, 2024 4:47 pm
