by kbrownie »
Sat Aug 01, 2009 3:38 pm
[quote="Escos"]P.S
As for choosing 16mm swa, it's to power a mig welder and compressor etc. Though not at the same time. I would rather spend extra and get it done right first time knowing that it will be able to cope with the ppower demand.
Do you think this is overkill then.?
Dale.[/quote]
No wise move, last thing you want is to go to trouble of intalling cable then findind out it's not suitable for purpose, the size of your cable will depend on the amount of current you need to supply the garage remember you'll have welder,comp, sockets and lighting.
Removing the seals is, dare I say it? commonly done by electricians, some are allowed to do this and some are not. DNO not fitting isolator switch don't surprise me, again some will some won't some charge some don't.
It's a little annoying for me that they don't, as the requiremnets(BS7671) state that all electrical equipment should have a means of isolation, now then I admit that the main fuse can be removed and isolate the supply to the CU but it's not an isolator and how are persons like you (no disrespect) know in case of emergency, how to remove the fuse?
That's my opinion I may get dressed down for it but heyho!
