Ceiling downlights
JohnK
Ceiling downlights
by JohnK » Tue May 29, 2007 12:30 am
Hi, First post, New build, Elect. has left site and left ceiling terminal blocks in roof space for downlights to be fitted. Have installed them using flat 1.0mm twin cable - do I need to clip all of these cables to meet the regs?
In bathroom moved single ceiling terminal box to roof space and replaced with 4 terminal junction box, and tailed out to downlights - suitable for Zone 1. Is this OK?
Many thanks
Jeffmo
by Jeffmo » Wed May 30, 2007 8:03 pm
hi , cables need to be 50mm above ceiling and 50mm below floor , if running with joists then these cables need to be clipped not exceeding 250mm , obviously against joists then either place cables in earthed steel conduit and notch out top of joists or drill through joists in centre line , maximum diameter 0.25 x joist depth .Hope this helps good luck . Regards Jeff
by sparx » Wed May 30, 2007 9:06 pm
Hi, yes should run cables where they won't be liable to damage, ie clipped to sides of timbers, in eaves etc,
J.B to lights fine , make sure cable outer sheath is in clamps of d/lighters, not just cores other wise all OK
regards SPARX
JohnK
by JohnK » Sat Jun 02, 2007 3:03 pm
Many thanks for all your help
John
It is currently Thu Dec 12, 2024 7:48 pm
