draining down C/H system
Steve Batch
by Steve Batch » Thu Aug 27, 2009 5:57 pm
I have an outside drain cock when I open it nothing comes out do I have to turn rads off?
by htg engineer » Fri Aug 28, 2009 8:50 pm
An outside drain cock ??? do you mean PRV ?
DRain from a drain point, on or near the boiler, near the pump or on the radiator valve, can't find any ?
Remove one radiator connect a cutting of 15mm pipe to the valve using a nut and olive and insert the pipe into a hose pipe - open the rad valve an it'll drain.
htg
Steve Batch
reply
by Steve Batch » Sat Aug 29, 2009 3:28 pm
[quote="htg engineer"]An outside drain cock ??? do you mean PRV ?
thanks, I have fitted a new drain cock the old one was stuck in its seat.
Steve the gas
by Steve the gas » Sun Aug 30, 2009 9:32 am
Beat me, thats the rubber stuck on its seat,very common.
It is currently Wed Jan 01, 2025 6:26 am
