Re-varnishing
cresser
Re-varnishing
by cresser » Fri Sep 11, 2009 4:31 pm
I have recently re-varnished an old(ish) telephone table, trying to liven it up a bit. After using wire wool to clean it up and wiping down with a damp cloth, ( I did then leave it to thoroughly dry), I applied the new varnish, but it is drying as if there is water either in the varnish or on the brush, giving a `dappled` effect. What have I done wrong here? cheers.
by stoneyboy » Sat Sep 12, 2009 11:19 am
cresser,
Chances are that the table has been polished using a spray with silicone in it, you could try cleaning the table with a universal solvent but if the silicone is deep in the grain more rubbing down will be needed.
cresser
by cresser » Sun Sep 13, 2009 9:25 am
Stoneyboy, many thanks for your reply. I would`nt mind betting your spot on, her indoors is always spraying something!! cheers again.
It is currently Fri Nov 22, 2024 10:37 am
