Differences between built in and built under gas ovens
Rastanking
by Rastanking » Sat Sep 19, 2009 9:10 am
Hi everyone,
I've been trying to find out the difference between built in and built under gas ovens. I am looking for a single gas oven/grill to be built under my worktop.
What are the differences between the two, if any, and can built in ovens be fitted underneath worktops?
Any help would be appreciated
Thanks in advance
Dan the man
by Dan the man » Sat Sep 19, 2009 7:47 pm
Same thing as far as I'm aware, you will need an oven housing to put the oven in though.
plumbbob
by plumbbob » Sat Sep 19, 2009 11:36 pm
Built under appliances may be designed to sit on the floor with part of the appliance hidden behind the plinth. This would look odd if installed at a higher level.
Built in appliances may be designed to sit fully in a housing which may be too tall to fit under a worktop.
Check dimensions carefully.
chris_on_tour2002
by chris_on_tour2002 » Tue Sep 29, 2009 10:23 am
'built in' in this context would refer to an oven incorporated into a tall cabinet so the oven door would be at around chest height.
built under will be an incorporated oven under the worktop, could be floor standing or completely inside cabinet housing.
It is currently Sat Nov 16, 2024 6:16 pm
