Broken Rad
CraigL
Broken Rad
by CraigL » Thu Sep 24, 2009 4:16 pm
I've damaged my inlet pipe to living room rad, the elbow joint is leaking
How can I stop the leak, until either myself or the local plumber fixes the leak, and will it require a new joint or is fixable?
by htg engineer » Sun Sep 27, 2009 11:15 am
The only way to staop the leak is to drain the system, replacing is probably the best option.
htg
It is currently Fri Jan 17, 2025 1:44 pm
