FIREPLACES
NARIB
FIREPLACES
by NARIB » Sat Mar 03, 2007 4:44 pm
I need to remove a wooden fireplace. Where do I start ? Any suggestions welcome. Thank you.
thedoctor
by thedoctor » Mon Mar 05, 2007 10:31 pm
Most timber fireplaces are held to the wall by little angle brackets which are screwed to the back of the timber and buried in the plaster. Its almost impssible to do this without some damage so usually its best to get a bolster chisel behind the mantle piece, directly above one of the pillars, and lever outward. This will allow you so see where the brackets are fixed.
thedoctor
by thedoctor » Fri Mar 16, 2007 1:44 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
It is currently Sun Dec 22, 2024 9:28 am
