Cool Shower
seadog
Cool Shower
by seadog » Tue Dec 29, 2009 11:49 am
Hi all,
I have two showers both on normal valves, gravity fed system with a 1.4bar pump, the outlets from the pump are split into two feeds, one for each shower. I have one shower directly below the pump and that one is nice and hot and powerful.
The problem is with the other shower which is about 30 feet away horizontally but the same distance as the other shower vertically. This shower is weaker and is significantly cooler. Sometimes it takes ages just to get cool. I can speed it up by removing the showerhead and blocking the hose for a few seconds, I then get a rush of bubbles followed by warmer water.
I am thinking the pump is not powerful enough to push the hot water that distance, any other ideas ?
rosebery
by rosebery » Thu Dec 31, 2009 9:44 am
How are the piped? What is the arrangement for the hot feed and is the cold feed different?
seadog
by seadog » Fri Jan 01, 2010 9:24 am
Hi Roseberry,
Cold feed to pump is from a CWST and hot feed is straight from the tank.
Outlet from the pump is then split into two to feed each shower.
rosebery
by rosebery » Fri Jan 01, 2010 12:33 pm
When you say straight from the tank do you mean from a flange (Surrey etc) in the top of the tank or do you mean a separate draw-off on the side of the tank or do you mean you've tee'd it off the vent?
seadog
by seadog » Sat Jan 02, 2010 8:04 pm
It's teed off the outlet that comes out the top of the tank.
It is currently Wed Jan 08, 2025 4:17 pm
