Combi boiler overflow pipe/blowout pipe
Sparkydelux
by Sparkydelux » Mon Jan 25, 2010 9:02 pm
I will be having a new combi boiler fitted and would like to know if the copper pipe used to extend the overflow outside can be joined using plastic push fit connections.
Many thanks
chris_on_tour2002
by chris_on_tour2002 » Tue Jan 26, 2010 2:24 pm
yes but why would you want to?
by htg engineer » Tue Jan 26, 2010 4:55 pm
Use compression or soldered, you could get 3 bar scalding hot water down this pipe. So you need to know the pipe is sound, and make sure it teminates - away from doors, windows, seating areas etc etc.
htg
It is currently Mon Nov 25, 2024 12:27 am
