Architrave and Skirting
7 posts   •   Page 1 of 1
acsimpson
by acsimpson » Wed Feb 03, 2010 10:03 am
I am putting new bullnose architrave and skirting into my living room and wonder what the best way to do the joint between them is? I am varnishing them so there is no option to fill and sand a gap.
Will it look best just to but the skirting up to the pencil edge on the architrave or should I try either trimming the architrave or profilling the skirting to match the edge?
acs
chips
Re: Architrave and Skirting
by chips » Wed Feb 03, 2010 7:01 pm
[quote="acsimpson"]Hi,
acs[/quote]
You could set the architrave on plinths of the same timber. Perhaps the supplier will sell them.
acsimpson
by acsimpson » Thu Feb 04, 2010 9:28 am
Thanks chips. Unfortunaltey in my haste to get the job done The architraves are already attached to the wall using glue. I could cut the bottom off them and create a plinth using an offcut of skirting but would it look OK having a plinth at the bottom and a mitre joint at the top of the doors?
chris_on_tour2002
by chris_on_tour2002 » Thu Feb 04, 2010 1:52 pm
are you having the pencil edge of the architrave facing outwards away from the door and the square edge inwards then? or is i 'D' profile?
you could rout out the edge of the skirting using a cove cutter of the same radius as the pencil edge then butt it up. otherwise, as chips has said, a plinth would probably offer the neatest solution.
acsimpson
by acsimpson » Fri Feb 05, 2010 12:35 pm
It's a double pencil edge on the architrave. I might pull the router out and see if I've got anything which will work. failing that I supose I could chisel a little out of the profile of the architrave and butt it that way.
If it all looks terrible at least I have the fall back option of cutting the bottom of the architrave and fitting a plinth in the future.
acsimpson
by acsimpson » Mon Feb 08, 2010 9:08 am
[quote="chris_on_tour2002"]you could rout out the edge of the skirting using a cove cutter of the same radius as the pencil edge then butt it up. otherwise, as chips has said, a plinth would probably offer the neatest solution.[/quote]
Thank you all for your advice. I went for a combination of router and dremmel to get the profile I needed and then butted it.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jun 28, 2010 9:55 pm
Discover how easy it is to find vetted and insured tradesman local to your area with the help of DIY Doctor. Visit our Find a Tradesman area: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Wed Nov 27, 2024 10:46 pm
