Plasterboard Jointing Cement
ml09616
by ml09616 » Fri Feb 05, 2010 9:45 am
Hi folks,
I have to install a plasterboard wall.
I will be using the self-adhesive tape on the joints.
Can I use a ready mixed PollyFilla type filler material to mud over the joints, or must I specifically use Jointing Cement.
I ask because I have enough ready mixed filler from a previous repair job to cover all the joints, and I'm not sure if there is anything special about the Jointing Cement.
regards
Mike
by stoneyboy » Fri Feb 05, 2010 8:43 pm
ml09616,
Ready mixed fillers tend to set really hard and are a pig to smooth, get the right jointing plaster it will save you a lot of hassle.
chris_on_tour2002
by chris_on_tour2002 » Mon Feb 08, 2010 3:06 pm
polyfilla style of fillers is also more likely to develop cracks with movement, as stoneyboy says it sets much harder.
jointing compound/scrim is the stuff to use.
It is currently Wed Nov 27, 2024 10:06 pm
