Fixing worktops to wall and concrete floors
rwyatt
by rwyatt » Tue Jun 05, 2007 1:04 pm
I am taking on a project for my work which is to fix a 6 meter worktop to wall and concrete floor in our new warehouse,
please could some explain how to go about this and what equipment/fixings I would need.
Some has suggested at work that I use expansion plugs in the floor, is this
right.
Robin
thedoctor
by thedoctor » Thu Jun 07, 2007 3:43 pm
Don't understand what you mean. fixing a worktop to a wall and a floor?
rwyatt
by rwyatt » Thu Jun 07, 2007 4:16 pm
I can only describe as a breakfast bar so would need to be fixed to wall and then via legs
thedoctor
by thedoctor » Fri Jun 08, 2007 10:24 am
Ahh ! First you fit a batten to the wall, at the correct heght for the underside of the worktop and slightly shorter than the top so you cannnot see the ends of the batten fromeither side. The batten should be about 50mm x 25mm with the 50mm face against the wall. The worktop sits on this batten and can be fixed to it, from underneath with brackets so no fixings are seen from the top. The brackets are available from the link below
http://www.awin1.com/pclick.php?p=82114 ... 071&m=1228
The legs are available, ready made and cut to length with great fixing brackets at the top. Follow the link below.
http://www.awin1.com/pclick.php?p=37360 ... 071&m=1228
rwyatt
by rwyatt » Fri Jun 08, 2007 10:37 am
What about fixing the legs to the floor, would using expansion plugs be ok?
It is currently Sun Jan 05, 2025 5:10 am
