I need to fit a stopcock into an existing hot water pipe from the cylinder so I can cut off the supply when changing tap washers in the bathroom washbasin.
I believe it's possible to freeze the pipes using an aerosol spray to save draining the tank but not sure how long this treatment would last while the new stopcock was fitted.
Any tips on materials or similar advice welcomed.
