Lighting
cabledeck
Lighting
by cabledeck » Wed Mar 24, 2010 10:20 am
Hi Folks
My problem is my landing light fitting. We have a longlife bulb in it which,every 5 seconds or so gives a dim flicker,so dim that it cannot be seen in daylight. I tested the fitting with a circuit tester and there is no reading whatsoever. I would be interested to here your comments.The switching is two way.
jackhawk
by jackhawk » Wed Mar 24, 2010 7:02 pm
After isolating supply to light at CU, remove switch, up and down if on a two way. Don't remove any wires from switch/switches. Check that all wires are tight and not loose. If thats ok try light fitting too. It sounds like you have a loose wire.
PS after removing light and/or switches, test to ensure it is dead please before touching anything within.
Regards
Jackhawk
cabledeck
by cabledeck » Wed Mar 24, 2010 9:47 pm
Thanks Jackhawk, as I speak it has now stopped. It seems that it may be as you say a loose wire.
Many thanks
Bob
It is currently Fri Nov 22, 2024 6:51 pm
