Kitchen lights problem
aimv
by aimv » Tue Mar 30, 2010 10:38 pm
I would appreciate some help.
For last couple of days, in my kitchen half of the things stopped working (spot lights and dish washer). Other things ceiling lights, cooker etc works fine. Don't know what happened just found one evening while switching spot line on.
I have checked main fuse and also replaced fuse of those switches(13A SWITCH FUSE) incase they blew off.
Any advise on what else to check?
Thanks,
Aimv
kbrownie
by kbrownie » Wed Mar 31, 2010 12:37 pm
Are the spotlights installed on the same circuit as the dishwasher?
This can be done by using a fused connection unit and down fusing off the circuit that runs the dishwasher.
If so I would check for loose connections at the socket where the dishwasher is plugged in to.
aimv
by aimv » Fri Apr 02, 2010 11:43 pm
Yes both are in the same circuit.
I already checked and there wasn't any loose connection. I would check it again anyway.
It is currently Thu Jan 16, 2025 11:49 pm
