Repairing plaster quickly in a bathroom to tile over again
Colin G
by Colin G » Sat Apr 03, 2010 4:52 pm
I am currently going to strip out the tiles in the bathroom (and change the suite), having done a few test areas some plaster has started to come off.
Is there a way that when the tiles are off, I can fix the wall within a day or two and start putting up tiles again as I need a quick turn around?
Can I get the plaster to dry quick or can I use a 'tile backer board' perhaps?
Any solutions would be great
Dan the man
by Dan the man » Sun Apr 04, 2010 4:39 pm
Use Carlite bonding or one coat plaster, it'll be ok to tile on the next day. If you use dirty water to mix it with it will go off quicker.
It is currently Fri Jan 10, 2025 10:52 pm
