DRY LINING QUESTION
toplondonchef
DRY LINING QUESTION
by toplondonchef » Sat Apr 10, 2010 11:51 pm
A quick question please...
I have a small area of wall (2400 x 950 mm) in my kitchen which I plan to dry line with plaster board, then use lining paper and emulsion
I know I should use drywall adhesive for dot and dab method of fixing board but wondered if I could just use bonding plaster on this small area or is this a bad mistake (adhesive comes in 25kg sack, only £7.00 I realise but I have a load of bonding plaster left from recent building works)
Wall being dry lined is plastered and emulsioned but in poor condition, hence dry lining option
Thanks for any views on the above
David
Dan the man
by Dan the man » Sun Apr 11, 2010 9:18 pm
Its not reccomended but we actually used to only use bonding years ago, it should be ok for that one board, dont mix it too stiff though and put plenty of dots on it.
toplondonchef
by toplondonchef » Thu Apr 15, 2010 8:45 pm
Thanks for your reply and advice Dan the Man - will go ahead with the bonding plaster option
I'm pretty happy this will give a good result but just wanted to double check as I'm really against bodging things up
Cheers again !
ricky68
by ricky68 » Sun Apr 18, 2010 6:44 pm
STOP BEING TIGHT,BUY THE RIGHT STUFF FOR THE JOB,ITS ONLY £6 TOPS.THERE IS NO ADHESIVE IN BONDING AND IT WILL COME LOOSE IN TIME.]
It is currently Mon Nov 25, 2024 4:50 pm
