cutting upto skirting when removing a timber floor
sbail
by sbail » Thu Jun 07, 2007 8:13 pm
Could anyone tell me which tool to use to cut upto skirting when removing the wooden floor menber from underneath it.
thedoctor
by thedoctor » Fri Jun 08, 2007 9:35 am
Not quite sure what a wooden floor member is but we are assuming you mean a floorboard. Use a tennon saw or wide, very sharp chislel if you only have one to do. If you have lots we would suggest buying a cheap Aligator, or Reciprocating saw. If you look in our project on replacing timber floors you will see all the equipent you need.
sbail
by sbail » Mon Jun 25, 2007 10:18 pm
The only problem using a saw is that the timber floor board is on concrete so you can not get an up and down movement.
biggles111
floor joists?
by biggles111 » Tue Jun 26, 2007 8:33 am
Are you talking about your floor boards or floor JOISTS. If you are planning to remove your joists be advised that if the structure is a timber frame your walls may be supported on these joists too.
If not then I suggest use a saw that you dont mind blunting a few forward teeth off to partialy cut through the joist. As you near the bottom of the joist hammer a wedge of wood either side of the cut to raise it off the concrete then continue to saw or chisel through.
sbail
by sbail » Tue Jun 26, 2007 6:58 pm
Removing a timber floor which is on concrete
thanks
Steve B
It is currently Mon Nov 25, 2024 3:27 am
