attaching ceramic tiles to a wooden surface
LES EATON
by LES EATON » Thu Apr 22, 2010 9:09 am
I am having problems fixing ceramic tiles to a wooden surface - not a good idea I know, but I have some piping in the bathroom that has been 'hidden' by a wooden surround and I'm trying to tile it to match the rest of the room.
I have given the wood a coat of PVA primer (1 part to 5 parts water) to seal it, but the ceramic tile fix doesn't hold - I'm thinking of using 'No More Nails' - or is there something else I can use.
by stoneyboy » Fri Apr 23, 2010 8:38 pm
LES EATON,
Try either tile fix designed for tiling on tiles or use a cementious based adhesive which incorporates latex (use for tiling on wood floors).
Data Recovery
Fixing ceramic tiles to a wooden surface
by Data Recovery » Thu Jul 01, 2010 1:10 pm
Hi buddy,
You may just try some flexible adhesive to fix the ceramic tiles with wooden surface.
You may directly sheet the floor with plywood then plenty of fixings through ply into joist before laying tiles.
Britt
It is currently Fri Nov 22, 2024 5:34 pm
