BATTENING KITCHEN CABINETS
gamblinharry
by gamblinharry » Tue May 11, 2010 7:26 pm
I am about to start installing a new kitchen & need to bring the wall units out by approximately 60mm. I will be screwing battens to the wall so I can attach 4 units to them (each unit is 500mm wide). To provide the best stability for the units, is is best to have a single batten for all 4 units or have separate battens for each unit?
Thanks in advance.
oddball
by oddball » Mon Jun 07, 2010 6:15 pm
Seems 1 single batt top and bottom would be easier?
Good luck.
chris_on_tour2002
by chris_on_tour2002 » Sun Jun 13, 2010 11:53 pm
makes more sense to just use the one. if you use many single pieces you've got the job of making sure that they are all level and flush with eachother. a single piece and you only have to level it once.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jun 28, 2010 9:34 pm
Discover how easy it is to find vetted and insured tradesman local to your area with the help of DIY Doctor. Visit our Find a Tradesman area: https://www.diydoctor.org.uk/find_tradesmen/
paul1985
Re: BATTENING KITCHEN CABINETS
by paul1985 » Sat Aug 17, 2013 12:35 am
For base units , install 2"x1" battern to the correct level and hight around the walls where base units will be fitted. On each unit cut out on both sides of each unit the battern dimension. Push unit against wall and screw unit legs until it hits the battern. This is the best way to install kitchen base units
It is currently Thu Jan 16, 2025 10:10 pm
