Best way to polish gloss paint to a smooth finish?
D-Mac
by D-Mac » Fri May 21, 2010 12:15 pm
Hello all,
I have just painted some kitchen units for my camper van in gloss paint. The finish is currently a slight orange peel effect (I used a foam roller) but what I would prefer is a smooth as glass finish. Can anybody recommend how I can achieve this? I'm initally thinking of using varying grades of wet and dry paper followed by a cutting paste as is used for auto paint finishing (t-cut type of thing). Does this sound right or is there a better way?
Also, is it possible/wise/necessary to spray lacquer over the top of gloss?
JRS
by JRS » Thu May 27, 2010 9:32 pm
Your roller is the problem. If its easier for you to use to prevent runners then once you have applied the gloss use a brush to (lay off) the paint. T-cut will do nothing apart from make a mess. Its not commercial car paint you have.
chris_on_tour2002
by chris_on_tour2002 » Mon Jun 14, 2010 12:54 am
the only way to get a glass-like finish with gloss paint is to use:
good quality paint - i'd recommend dulux trade liquid gloss
a brush, NOT a roller
good brushing technique which only comes with practice.
rollers are ok and a nifty shortcut in certain applications, but will not give as good a finish as a brush.
also if you are going to use a roller, use flocked not foam - air bubbles from the foam will be left in the paint.
It is currently Wed Dec 04, 2024 8:44 am
