Faulty immersion thermostat?
danhotrod
by danhotrod » Sun Jun 10, 2007 10:12 pm
Evening all...
I'm having a spot of bother with a couple of things:
1. Even when my CH is turned off, my radiators are getting hot when the HW program comes on.
2. My mixer shower, which is fed from a shower pump, is only delivering hot water.
I suspect I need a new thermostat on my immersion heater. Are these two problems related? Any advice gratefully received!
devilsback
by devilsback » Sun Jun 17, 2007 12:02 pm
no, they aint related to your thermostat on the emmersion. I assume you have a system boier and depending on what type of system you have , it sounds like a faulty diverter, two port or three port valve but you should get a heating engineer in to check your system
It is currently Mon Dec 23, 2024 7:56 am
