Walls lights after decorating
christine1963
by christine1963 » Fri Jul 09, 2010 11:54 am
We recently decorated our lounge before which we removed our wall lights, but since putting them back and after several checks to ensure they are wired the same way, they still don't work. Bulbs have been checked in other fittings are ok. We have also checked the switch, at skirting board level to ensure that doesn't have a loose wire. Any suggestions where to look next please? Should we buy new fittings?
MALPASS
lights dont work
by MALPASS » Fri Jul 09, 2010 11:06 pm
Have you checked their is supply getting to them ? try the mcb or fuse , put a test on to see if the feed wire is live , best of all if you can aford it get a qualified electrician in
It is currently Tue Nov 26, 2024 3:43 pm
