Which boiler for a 5 bedroomed semi?
tomcubi
by tomcubi » Sun Aug 15, 2010 2:58 pm
Thanks in advance for your advice.
What boiler would you use for a 5 bedroomed semi-detached victorian property: 2 en-suite, 1 bathroom, gas hobs and gas central heating.
The price, as always is very important.
Glow-worm 35 cx?
Glowworm Xtramax HE combi?
Baxi boiler?
I am sure you'll come up with other models..
Thanks again
eggers
by eggers » Wed Aug 18, 2010 10:15 pm
are you looking to have a combi boiler or a boiler and hot water storage?
oli-spark
by oli-spark » Wed Aug 25, 2010 11:56 am
Just a thought to bear in mind regarding running costs
Most boilers are similar in basic efficiency most of the difference in running costs (when installed in the same building etc) comes from the controls
There is a huge difference in accuracy between an old bi-metalic thermostat and a new electronic types with a switching differential of 0.5degrees
Electronic stats can be very simple dial and numbers or fully programmable
If you can get weather compensation on your condensing boiler as a reasonably cheap (£50-100) option it is well worth taking because it will keep your boiler in condensing mode most of the time
A boiler when condensing is about 15% more efficient than when not condensing (the whole point of a condensing boiler) so maximise the time it condenses!
