cutting mosaic tiles
JIM PERKINS
by JIM PERKINS » Mon Aug 16, 2010 6:12 pm
I am having a go at tiling with mosaic tiles around my bathroom window.
On the inside of the window (either side of the windwsill i end up with half a small tile left, whats the best way to cut them.
I'M also lookng at tiling over the exsiting tiles,as long as there clean i cant see a problem.
I want to tile down to the floor (i have large skirtinng boards aorund the sides of the bathroom and the protrude out a bit from the tiles that are already up,if i take the skirting boards off would i be ok using plaster board to fill this place.
by stoneyboy » Mon Aug 16, 2010 11:32 pm
JIM PERKINS,
Score the tiles and use a tile breaking pliers to snap them along the score line.
Unless you can seal the floor to the walls plasterboard is not suitable in a bathroom use one of the aqua boards instead.
It is currently Fri Nov 22, 2024 7:32 pm
