Lime mortar pointing mix ?
bb700
by bb700 » Tue Aug 24, 2010 7:14 pm
The first time I did some pointing on my old house , I mixed the Lime into a paste stored it in a airtight container & then run off the surplus water before mixing with sand & cement.
I need to do some more pointing (only a small area about 2 ft square).
Can I mix the Lime powder with sand before adding to cement or will I have to prepare the Lime as I originally did.
Thanks.
by stoneyboy » Fri Aug 27, 2010 1:14 am
bb700,
You can mix the lime and sand together but should not be using cement.
Don't mix more than you can use in about an hour.
It is currently Sat Nov 23, 2024 1:16 pm
