How do I wire a ROBUS RRF10 Thermonstat
KenRita
by KenRita » Sun Aug 29, 2010 6:39 pm
I have a ROBUS RRF10 thermostat and have tried to wire it to switch an electric fan heater and can not get it to work.
Inside the cover is a wireing diagram for each terminal, 2 Live in, 3 Negative in (if used for heating), 4 Negative in (if used for cooling), 5 & 6 with no indication what they are for, just a circle with a cross in it. I thought this was for the heater.
The unit has terminals 2, 3, 4, 1, 5 and 6, in that order.
The wireing instruction sheet states.
D. For heating control use the normally closed contact (terminals 2 and 3) or for cooling use the normally open contacts (terminals 2 and 4).
E. For the neon indicator, a neutral line is required. Connect N to terminal 6 and link terminal 5 to either terminal 4 or 3 to show heating or cooling is required.
It seems simple and probably is but I can't get it to work.
Please can anyone offer assistance.
by ericmark » Mon Aug 30, 2010 2:29 am
You ask how then give answer!
In
Line to terminal 2
Neutral to terminal 6
Out
Line to terminal 3
Plus link from terminal 5 to terminal 3
And of course earths connected together.
Remember only rated at 10A resistive so max is 2Kw do not use a 3Kw model.
Malinois
Re: How do I wire a ROBUS RRF10 Thermonstat
by Malinois » Sun Oct 13, 2013 7:11 pm
I am trying to wire up a Robus Thermostat. I thought it would just be a case of swapping over but plainly not.
The way it is currently wired is the only configuration I have found that does not blow a fuse.
Links to images are below.
Can someone please clarify it for me?
Many thanks
Ian
https://dl-web.dropbox.com/get/Camera%20Uploads/2013-10-13%2016.17.43.jpg?w=AADseCggYZypZmyKjJ4jzi_NrbdTf5kmQ0fpKiUNnqqKTw
https://dl-web.dropbox.com/get/Camera%20Uploads/2013-10-13%2016.46.23.jpg?w=AABsNKdeff4GHfzWyFMVrMOWQK0S1YO1Leijc5lwoZNizw
Malinois
by Malinois » Sun Oct 13, 2013 9:52 pm
It is currently Tue Jan 14, 2025 11:44 pm
