Emulsion paint drying in strange patterns on chimney breast!
6 posts   •   Page 1 of 1
payney
by payney » Tue Sep 28, 2010 3:04 pm
Hi guys!
I've got a strange problem with my living room chimney breast!
For some reason, when it's been painted with emulsion (3 good coats now) the top right corner keeps drying in strange patterns. The rest of it is fine.
It's all got the same paper underneath, and is completely flat, so I'm at a bit of a loss for the patterns that keep appearing!
Here's a link to a photo of the problem:
http://img827.imageshack.us/img827/20/photoas.jpg
Any ideas would be much appreciated!
Thanks!
:D
by stoneyboy » Wed Sep 29, 2010 11:35 pm
payney,
Possibly wall paper paste on the paper below leaching through, try using oil based undercoat over area affected then repaint with your emulsion.
JRS
by JRS » Thu Sep 30, 2010 9:09 pm
Any better pics? Are you sure its not just that the top right is dry and the rest is staying damp due to the chimney breast i have seen that before.
payney
by payney » Fri Oct 01, 2010 11:45 am
@Stoneyboy - that's a good idea - thanks!
JRS - it's been nearly a week and it's still like that, so deffo not a damp/drying issue.
Thanks for the feedback guys, much appreciated! :D
theshedman
by theshedman » Fri Oct 01, 2010 2:08 pm
Hi payney, I think JRS was saying that there could be some damp in the chimney breast itself which is causing it. Sometimes water comes down the inside of it and stains the outside. Or if it is a bungalow there could be a problem on the outside of the property which is causing the damp ie flashing or surrounding tiles. If you do try stoneyboy's approach it will stop any more coming through in the area you put the oil based undercoat ( I always mix oil based undercoat and gloss 50/50 myself as that always works for me but each to their own, if it works for you use it I say) but if it is due to damp in the chimney it will come through somewhere else.
JRS
by JRS » Sat Oct 02, 2010 10:34 pm
theshedman wrote:Hi payney, I think JRS was saying that there could be some damp in the chimney breast itself which is causing it. Sometimes water comes down the inside of it and stains the outside. Or if it is a bungalow there could be a problem on the outside of the property which is causing the damp ie flashing or surrounding tiles. If you do try stoneyboy's approach it will stop any more coming through in the area you put the oil based undercoat ( I always mix oil based undercoat and gloss 50/50 myself as that always works for me but each to their own, if it works for you use it I say) but if it is due to damp in the chimney it will come through somewhere else.
Thank for clearing that up mate. As he said. Try oil based but if it comes back you will need to find the source of the dampness or it will keep coming back no matter what you use.
It is currently Fri Jan 10, 2025 8:00 pm
