Gable wall
lexus68
Gable wall
by lexus68 » Tue Sep 28, 2010 6:06 pm
Hi. My house was a terraced house but now is an end terrace due to having two houses demolished next door. Now my gable wall is only a single skin wall which I think is about 9mm. I would like too know if having insulation put in between exixting gable wall then rendering the gable wall is better or having the insulation put in and building a brick wall would be better?
Also if I was too have a brick wall built would it compromise the foundations?
by stoneyboy » Wed Sep 29, 2010 11:12 pm
lexus68,
Adding an outer brick skin will be better but you may need to extend the existing foundations.
It is currently Fri Dec 27, 2024 8:58 am
