Can I emulsion on to a wall without a primer?
Judyk
by Judyk » Tue Oct 19, 2010 4:22 pm
I have just removed wallpaper, the walls are not all the same colour. I notice that some look ok but others seem brown shading on. Not flaky, is there a primer I could use on them first to give a good base for emulsion. The finish colour is important as I am going beige. Is Dulux the best or Crown and two coats I presume
by stoneyboy » Tue Oct 19, 2010 7:01 pm
Judyk,
Try applying a well thinned coat of white emulsion. If staining bleeds through this coat you will need to apply a coat or two of oil based matt paint to seal the surface.
JRS
by JRS » Fri Oct 22, 2010 8:23 pm
Depends on colour, if they are dark like blue / red black then deffo 2 coats of white will be needed. The walls will need a good sanding to get rid of any paste possible a wash with sugar soap. But if light colours then 2 coats of dulux i would recommend will be sufficient.
It is currently Sat Nov 16, 2024 6:22 pm
