Metal plate behind gas fire
mncollyer
by mncollyer » Wed Oct 20, 2010 3:17 pm
While decorating I have found the metal plate behind the fire has come unstuck from the wall, can I just use a fabric type tape or is there a special tape required.
Thanks Mark
by htg engineer » Thu Oct 21, 2010 9:49 pm
You need closure plate tape, but you should also get an RGI and don't use fire until it has been checked, as if the closure plate has come away it is not adequately sealed.
htg
mncollyer
by mncollyer » Sun Oct 24, 2010 4:50 pm
htg engineer wrote:You need closure plate tape, but you should also get an RGI and don't use fire until it has been checked, as if the closure plate has come away it is not adequately sealed.
htg
Thanks for the reply.
Mark
neenee6969
by neenee6969 » Thu Dec 16, 2010 1:49 pm
hi had council fit a gas fire they put a back plate on but it got a 10mm gap between plate and wall sealed with duck tape which has now come away from the wall i would jst like to know if this is safe????also i was told by 1 fitter that they needed to remove the flue after a back boiler was removed but left in place but now someone else is saying an anti down draft cowel should be fitted any help would be apprecated thanks
It is currently Mon Jan 06, 2025 10:55 am
