Underfloor insulation - can I do this?
b9jobber
by b9jobber » Tue Nov 16, 2010 10:28 pm
I've got a 1930s semi with groundfloor suspended wooden floors.
I've taken up the carpets to expose the tong n groove floorboards - downside is the boards are cold in winter.
Just a thought - could I inject cavity wall insulation under floorbards to keep out draughts? The cavity is about 18" deep to soil.
I don't fancy pulling up each board to insulate under them - it'll cost an arm and a leg to replace split/damaged boards.
What do you think?
draughty floor
by welsh brickie » Wed Nov 17, 2010 12:48 pm
you could tack 3mm ply and tape the joints on the floor then relay the carpet.
It would cost a fortune to inject cavity wall insulation under the floor.And the gap under the joists is there for a reason it should be kept clear.
b9jobber
Re: draughty floor
by b9jobber » Wed Nov 17, 2010 10:46 pm
welsh brickie wrote:you could tack 3mm ply and tape the joints on the floor then relay the carpet.
cheers mate, but we like the exposed boards. Spose will have to suffer the cold..........
It is currently Wed Jan 08, 2025 10:36 pm
