mixed up wires?
judiM
mixed up wires?
by judiM » Thu Nov 18, 2010 3:24 pm
I've just changed a ceiling light fitting in a bedroom that the previous occupier installed.
I've done other light fittings in the house no problem, my usual tactic is to take a photo of the old wiring and then copy it exactly! this time I unscrewed the metal dome fixed to the ceiling and it came down, presumably meaning the wires in the ceiling weren't screwed into the light terminals, just shoved in.
There were 4 wires - earth and 3 black wires (a single bit of red sleeve had come down with the light). 2 of the black wires were twisted together a bit so I assumed these to be neutral and wired up the light - it works fine.
Apologies if I'm being really paranoid (and a bit dense), but could they be the wrong way round? I've tried googling and answers seem to vary, I assumed it would trip the switch on the consumer unit if wrong or just not work? but some answers say it would work but will get too hot/give a shock later.
Thanks for reading
J
by ericmark » Thu Nov 18, 2010 9:31 pm
As long as earth in right place then:-
It will work A1
It will blow fuse when switched on
It will work dim and other room lights also affected.
Those are the three options.
It is currently Thu Jan 16, 2025 6:39 am
