plasterboard jointing
bateman
by bateman » Sun Jan 30, 2011 7:33 pm
one small question is the tape used for plasterboard joints self adesive (do i have to wet it) or use a adesive
by stoneyboy » Sun Jan 30, 2011 9:06 pm
bateman,
If you are using taper edge boards then use a jointing tape which is stuck in place using the filler. If they are square edge use self adhesive plastering scrim.
toplondonchef
by toplondonchef » Sun Jan 30, 2011 9:13 pm
Hi Bateman
Use self adhesive scrim tape straight from the roll - couldn't be easier
Just position it centrally over the joints and smooth it down as you apply it
The non adhesive tape has to be stuck to the boards using either a jointing filler or plaster - more mess - more work - more hassle
Good luck and hope that this info helps you
It is currently Fri Nov 22, 2024 6:11 pm
