Flue Liner/ Chimney Exit
raeargyll
by raeargyll » Thu Feb 17, 2011 9:56 pm
When installing a flue liner is there a minimum high from the roof that it must protrude using a macflash or similar.
The existing chimneyhead was removed below roof hight and would need to have steel upright inserted out through the tiles/slates.
by stoneyboy » Fri Feb 18, 2011 6:40 pm
raeargyll,
Depends what it is serving, you need to look at the building regulations because it depends on your roof geometry.
flue liner
by welsh brickie » Sat Feb 19, 2011 4:49 pm
usually 1metre above ridge height for chimney,I assume its the same. consult the suppliers for technical info
Perry525
by Perry525 » Thu Mar 03, 2011 7:09 pm
As Welsh writes it must rise at least one metre above the highest part of the roof. In any event the chimney must extend more than 16 feet above the highest opening in the fire.
Less than 16 feet and you will have problems with smoke.
It is currently Sun Dec 22, 2024 7:17 am
